Γεια σας και ευχαριστούμε που ήρθατε μαζί μας! Καταχωρίστε έναν δωρεάν λογαριασμό σήμερα για να γίνετε μέλος! Μόλις συνδεθείτε, θα μπορείτε να συμμετέχετε σε αυτόν τον ιστότοπο προσθέτοντας τα δικά σας θέματα και αναρτήσεις, καθώς και να επικοινωνείτε με άλλα μέλη μέσω των δικών σας ιδιωτικών εισερχομένων!
Πρόσφατο (Software Update) New Firmware for ICOM IC-9700
Firmware
IC-9700
Version 1.50
2025/08/21
Changes from Version 1.44
  • The CS-9700 programming software used with this firmware can be downloaded here.
  • To update the firmware
  • 1. Download and unzip the firmware data (for example, 9700E150.dat) and copy it into the “IC-9700” folder that is on your SD card.
  • 2. Insert the SD card with the firmware data into the transceiver.
  • 3. If you are updating the firmware from version 1.11 or earlier, the transceiver will not display a dialog to recommend saving the settings and memories described in step 4-4, so we recommend backing them up on the SD card in case the settings and memories are reset.
  • - If you are updating the firmware from version 1.13 or later, proceed to step 4.
  • 3-1. Display the SD CARD screen in the Menu.
  • 3-2. Touch “Save Setting” on the SD CARD screen to open the SAVE SETTING screen.
  • 3-3. Touch <<New File>> to display the FILE NAME screen.
  • 3-4. Touch [ENT], and then the dialog “Save file?” is displayed, touch [YES].
  • 4. Update the firmware.
  • 4-1. Display the SD CARD screen in the Menu.
  • 4-2. Touch “Firmware Update” on the SD CARD screen to open the FIRMWARE UPDATE screen.
  • 4-3. Touch [▼] to scroll to the end of the screen to read all the precautions, after you read and agree with all the precautions, touch [YES].
  • 4-4. If you are updating the firmware from version 1.13 or later, the confirmation dialog recommends making a backup of the settings and memories, touch [YES].
  • We recommend that you make a backup of them in this step, because all the settings and memories may be reset after updating the firmware.
  • - If you are updating the firmware from version 1.11 or earlier, skip this step, and then the transceiver displays the firmware selection screen.
  • 4-5. After the backup file is made, and the firmware selection screen is displayed, touch the firmware update data (for example, 9700E150).
  • 4-6. Please carefully read all the precautions, and when you want to execute it, touch [Yes] for 1 second to start the firmware update.
  • 4-7. When the update is completed, "Firmware updating has completed.” is displayed, and the transceiver will automatically restart.
  • If the setting data needs to be converted, it may take some time to restart.
  • 5. If the settings and memories have been reset, load the settings and memories that have been backed up onto the SD card.
  • 5-1. Display the SD CARD screen in the Menu.
  • 5-2. Touch “Load Setting” on the SD CARD screen to open the LOAD SETTING screen.
  • 5-3. Touch the file name of the saved file.
  • 5-4. Touch “ALL,” and then the dialog “Keep ‘SKIP’ settings in the Repeater List?” is displayed, touch [YES].
  • 5-5. The dialog "Load file? The new “REF Adjust” setting will be saved.” is displayed, touch [Yes].
  • 5-6. After the loading ends, “COMPLETED! Restart the IC-9700.” is displayed, restart the transceiver.
  • After updating the firmware, the Version Information in the OTHERS Set will be as follows.
  • Main CPU: 1.50
  • Sub CPU: 1.00
  • Front CPU: 1.00
  • FPGA Program: 1.08
  • FPGA Data: 1.00
  • DV DSP: 1.10
DOWNLOAD
