| Firmware |
| IC-7300MK2 |
| Version 1.02 |
| 2025/11/13 |
- To update the firmware
- 1. Download and unzip the firmware data (for example, 7300MK2_102.dat) and copy it into the “IC-7300MK2” folder on your SD card.
- 2. Insert the SD card with the firmware data into the transceiver.
- 3. Update the firmware.
- 3-1. Display the SD CARD screen in the Menu.
- 3-2. Touch “Firmware Update” on the SD CARD screen to open the FIRMWARE UPDATE screen.
- 3-3. Touch [▼] to scroll to the end of the screen to read all the precautions, after you have read and agreed with all the precautions, touch [YES].
- 3-4. The confirmation dialog recommends backing up the settings and memories by touching [YES].
We recommend backing them up in this step because updating the firmware may reset all the settings and memories.
3-5. After the backup file is made, and the firmware selection screen is displayed, touch the firmware update data (for example, 7300MK2_102). - 3-6. Please carefully read all the precautions, and when you want to execute it, touch [YES] for 1 second to start the firmware update.
- 3-7. When the update is completed, "Firmware updating has completed.” is displayed, and the transceiver will automatically restart.
- If the setting data needs to be converted, it may take some time to restart.
- 4. If the settings and memories have been reset, load the settings and memories that have been backed up onto the SD card.
- 4-1. Display the SD CARD screen in the Menu.
- 4-2. Touch “Load Setting” on the SD CARD screen to open the LOAD SETTING screen.
- 4-3. Touch the file name of the saved file.
- 4-4. Touch “ALL,” and then the dialog “Load file? The new “REF Adjust” is displayed, touch [YES].
- 4-5. After the loading ends, “COMPLETED! Restart the IC-7300MK2.” is displayed, restart the transceiver.
- After updating the firmware, the Version Information in the OTHERS Set will be as follows.
- Main CPU: 1.02
- DSP Program: 1.01
- DSP Data: 1.00
- FPGA: 1.01
